i work for nissan i am a parts man not a mechanic but i belive the cable is under the floor carpet but are you sure that the latch hasnt snapped were the cable connects to it as that is a realy common problem and if not the cable is seized and will need replacing its the same on all k12's your local nissan dealer could get them the next day if you order b4 11:00am there not too expensive hope this helps cheers
