Replacement key
Hi all.
Where can I get a replacement key cut for my 1999 Micra 1.0, other than from a Nissan dealer? I have two original keys with the car but one has just snapped and the other seems weak, so I would like to use it as a pattern for a new key to be cut.
I don't need the electronic bit in the key head to lock & unlock the door remotely, just a simple key to use manually, as long as it will start the car!
Would it be possible to get a second-hand key and have it re-programmed? If so, by whom?
All useful suggestions will be much appreciated.
Thanks.
