Good afternoon, I've tried finding an answer in the back-catalogue of abs threads but couldn't see an answer for my specific question; If I can get a salvage replacement ABS module, will it need reprogramming?
I've got a 160SR that has had the handbrake, esp, and ABS warning lights come on intermittently when starting. For a little while this would clear if I cycled the ignition, but I've been looking for sources of a replacement ABS unit in anticipation of it failing. The lights are now on permanently and a code reader shows "ABS control unit failure", so I need to get it to a garage.
What I want to do is take it to a repair and electronics specialist garage and ask them to investigate, diagnose and confirm the abs module has failed, and get a quote for installing a replacement unit. Ideally then I'd be able to provide the donor unit and have them fit it, but does anyone know if the abs modules need reprogramming to the new car? I'm aware the 160SR and C+Cs have a slightly different unit to the other k12s, if I can get a salvaged C+C unit would this be a simple job to get a garage to install?
Many thanks if anyone is able to help and save some running around.
