Replace or fix?
CMF_RedK11
hi all, my right front fender is dented.
Is it possible to fix this? Or is it easier and cheaper to replace?
Replacing it would cost about $175 from wrecker which i can give it a go to paint and install myself. I'm inexperienced in panel beating but if someone can give me a few tips and tricks, i can give it a go in fixing it myself (and save some bucks).
CMF_Micra_King
frank2 WROTE:
"you should be able to pull that back into shape with your hands once the bumper is unbolted (they,re only piss thin eh)
True but use a hair dryer to heat the area you will be bending back as it makes the paint go a bit soft and malleable and stops it from cracking and also makes bending the metal back easier. Just dont overheat the paint or you will burn it.
