Removing the bottom section to the fuse box
Hi all,
So my front left headlight isn't working. I have check the fuse itself, the relay, the ground connection and then found the voltage drops under load so want to remove the bottom of the fuse box to remove the wires leading to the headlight.
The issue is I can't get the damn box apart, been trying for 30 mins or so and am close to just smashing the thing so any help would be muchly appreciated.
In the phot my finger is point to the part I want to disconnect from the top part. I have undone two clips at the front but can't find anything on the back that is like a latch or similar.
Josh
