Removing SuperS spoiler
goldstar0011
I need to take my SuperS spoiler off, but need to do it without breaking anything as the last time I removed one it was off a scrap car so didn't worry about the car.
Please help
theres two 12mmbolts iirc in top left and right corners...
open boot and check under small round sticky cover things...
then two thirds down on each side someclips...
these may break so hold on tight and pull slowly, a flat screwdriver may help...
i did this when i took mine off from scrappers... i dint want to dameg anything...
hope this helps:)
is it the wrap round one?
If so....2 mins let me think bout this.
Ok i think i remember now, open the boort and iirc theres two screws on the top like at the top of the rear window. Unscrew them, might be caps on em or summit cant remember exactly. Also, theres two plastci clips on each "arm" bout 3/4 of the way down. You will need something flat, thin and sharp. Then like pry the spoiler off as it will be held on with thwat stupid tar like stuff that Nissan so seem to love!
Then just pry it away, i may be wrong though...
