Pull the plastic cover off the washer arm where it attatches to the car and remove the retaining nut, the arm should pull off. Open the boot and remove the inside cover, take out the three bolts holding the motor, undo the electrics plug to it and take the motor out. I would weld a plate over the inside of the hole and fill the outside with P38.
