Removing rear side windows
neilos
Does anyone know how easy it is to remove the side windows on a 3-door?
I wanna take them out to give the glass a proper clean and also clean all the gunk thats got stuck inbetween where the glass sits againast the bodywork. My fingers can't get in there to clean it.
take it they are pop outs with yours beeing a 1.3? they just unscrew, there maybe some plastic covers over the screws just pop them off with a flat blade then unscrew the screws hold the windows in place.
Thread moved. The guides section should only be used for submitting instructions / procedures on how to fix things etc :)
Pop outs there is a screw behind the passenger seatbelt and 2 are behind the plastic in the pillar.
Fixed, you just need to pull the rubber seal on the inside off and then the window is loose.
I clean that gunk off using a pressure washer though!
