Removing rear seat - how?!!
Robert
I have the backs off but stuck with the cushion, I've taken two bolts out of the back holding them to the boot floor, but can't find the bolts on the front edge, or the plastic covers the Haynes mentions..
Can anyone help me out? (split folding seats in a facelift if it makes a difference..)
Cheers guys!
back rests have to come off (8 bolts all together) then after unbolting the 2 bolts on the bottem bench, the bottem bench just lifts up with force..and its off :)
there is 8 bolts to take out of the back of the top parts of the seats then the 2 12 mm nuts that hold the seat in place on the wheel arch after they are off and the 2 12mm bolts that hold the back end of the seat to the car you have 2 bench gromits (i fit them at work btw) that you have to prise out mate if you stick a pic up with what you are left with im sure i can help you
All out now, thanks :)
Haynes made out there were bolts at the front of the seats too which is why i was confused and didn't want to go just pulling on it!
