Remove and Replace K11 Door
Hi,
After picking up a nasty gouge in the rear left door on my 5 door 02 reg K11 micra I'm looking to pick up a replacement from a breakers yard and replace. I can get the right colour door with all the glass and correct trim etc. in place so I'm hoping for a straight swap. Even if the paint is slightly off, can't be as bad as the door looks now!
Has anyone done this? Anything to look out for?
I hope the central locking will work as before?
As far as I understand it's as straight forward as:
- Disconnect Wiring Harness
- Remove pin or unbolt door hinge
Reverse to add new door?
Thanks in advance,
Simon
