take off the door cards, and where the handles are theres 2 10mm bolts, undo them, and theres a metal rod you need to take out aswell. its abit tricky to put the rod back in....oh also where the rod goes into the platic of the handle its really sensitive, i snapped them as i was give the handles some abuse! lol so ended up throwing them. as with out the plastic for the metal rod to go into, the handles dont work, as the rod is used to open the lock
lol you will understand abit better as you go along, ive kind of put it in a hard to understand way :S
