remote amp install
Dragonmaster_uk
K12 NUTTER
without going into too much detail here what i`m looking to do is fit an amp into my car not connected to a headunit now i`m pretty sure the earth main power and audio leads would be wired up as normal but where would i be able to take the little remote signal from that actually turns the amp on the amp will be mounted in the boot if this helps
it`s in a k12
thanks in advance i`m sure someone will know an easy answer to this
If you want to turn the amp on yourself manually, i'd say splice off from the constant 12V from the battery and just add a switch before it goes into the remote input as the remote is just looking for a 12V feed to turn on the amp.
Crude diagram:
i wanted the same thing and wired in a switch on the remote wire from my headunit, but im sure that any +12V feed would do as the remote wire.
