I think it's just a plastic case with a standard issue 40A automotive relay inside, the bottom will give up it's secrets and possibly save you a few bob.
wierd, not a standard relay type. You could get a replacement standard automotive 4 pin relay and socket and wire into the original socket, other than the pin configuration its pretty standard... is that for a coilpack car?
