Having found that the rear track on the K12 is 35mm narrower than the front I thought that I could remedy it with a pair of 15mm spacers on the rear. Sadly the 15mm hubcentric spacers won't fit as the 60.1mm spigot on the rear brake drums stick out further than the recess in the 15mm spacers will accept. :0(.
I'm told that the 20mm spacers have a deep enough recess for the spacers to fit flush with the brake drum but not sure of wheel arch clearances with these? Has anyone on here fitted 20mm spacers with the standard 16" (160SR) alloys? are there clearance problems?
