1) Is changing the Rear Wheel Bearings relatively simple ??
My car has just beeen through an MOT & failed on "rear wheel bearing feels rough when rotated".
Anyone know what this means ??
I have just changed brake shoe on that rear wheel & you can slightly "feel" the bearing at points when wheel is rotated. But it's not very much & still smooth.
Is being able to feel the bearing ok or not ??
Is that what it means, should it be completely smooth & you should not be able to feel the bearing when wheel is rotated ??
2) When I changed rear brake shoe, outer bearing came out with brake drum.
I did not remove inner bearing.
Do you just remove Grease Seal to remove Inner Bearing from brake drum ??
Is that it or is there anything more to it ??
And where do you get the Grease Seal, as they say not to reuse ??
