Retepetsir
King of Subsonic
Hi guys, its not often that I'm in this section, but I need a bit of guidance! My MOT is due next month, and it'll be the first one since the suspension work (springs and dampers and panhard rod)....but I've got one slight concern about the rear wheels.
The left and right rears seemed to be positioned differently in relation to the car body. When you look at the car from behind, the right hand wheel seems to stick out of the car slightly more than the left, with the top left of the wheel noticably more recessed into the wheel arch....
I've try to show this in the photos below, and just wondering if I've got a problem? A Whiteline panhard rod is also fitted, and set to the minimal possible setting, so I'm not sure what else I should do, if anything?
Right Rear:
Left Rear:
Any advice would be greatly received!
Pete
Right Rear:
Left Rear:
Pete
