L
Littleleigh
Hey, just asking if anyone knows why my rear washer is not working, i swear it worked before. the front works fine, but when i try and use the back, no luck, although a trickle from time to time. in this weather it aint good. :down: (Yes the washer fluid is full):wasntme:
Oh and recently i fitted a chavvy exhaust tip 4". and cut off the old one partly so it could fit on nicely. does anyone know if the result of this causes the exhaust to rattle a little bit because its seems as tough it has.
Has anyone tried this? other than the rattle, it repetedly POP's (you know, like the sports exhausts). sounds cool.
Anyway if you guys can help that would be cool. thanks
