My 1993 k11 was in need of sanding ground points, replacing the tail light lamp holders and checking out custom wiring which came with when I bought my car. Probably annual inspection does not require to have a working rear fog light since it wasn't mentioned. But I'm planning to use my Micra as daily driver. My job requires me to drive my car trough a great part of my country and that at times that bad weather might occur.
But I have zero volts on my rear fog light and the front is working. I checked my fuses but I wonder from here, how to start fault checking with a multimeter?
Or even better does someone recognize this as a malfunction that is known to the k11?
