Hi can anyone advise hoe to remove and replace the indicator bulb in the rear cluster of my k12 micra I have loosened the bolts that i can see but it still seems to be held somehow? im a girly DIYr so can you keep it simple thanks!
if you`ve loosened the two bolts then you just have to pull the cluster away from the car there is a clip on the far side of the light about where the bumper meets the rear quater that needs to come out
