Right lads I've looked high and low and can only find them available on the continent so hoping that one of you have a PN or place to source them.
They're for my Cube and as most of you will probably know they're pretty much identical to a K11 mechanically.
The Cube braking system- Rev 1 Z10's (mine) have the same 1 pots as found on Micra's, however the 2nd revision Z10 (my breaker) have larger 1 pots that use larger pads and thicker discs, I'm not sure what other model shares this caliper tbh.
Rear brake drums have ABS and although drums are physically the same as Micra's, the shoes are different. From looking at the countless PN equivalents it would seem that the ABS March models share them.
Nissan PN 44060-41B25 or 44060-2U025 (several others seem to verge onto Micra specific ones oddly but this pn is definitely the right one)
Considering we're in the UK the Blue print number is ADN14147 now these are the correct ones but everywhere nationally are out of stock so it seems to me like it may be an older part number?
Hopefully someone on here has some ideas!
