rear axle moved back on right side?
CMF_DECIM8
hey peoples.↲↲
i have a slight issue with the micra. It is rubbing the rear right side of the bumper. It has good bushes and a panhard bar. Could i offset this axle movement by lifting that side by a cm or so? ↲ the coilover i have are set at exactly the same height but this right side looks slightly lower. Any advice? Could it just be too low?
CMF_DECIM8
yeah. Im thinking with the curve its too short. It took quite abit of force to get it on too. I had to push the assembly over while mounting. I'm thinking its no good and pullin rather than pushing.
CMF_DECIM8
? i figure longer as it pushes the axle out to body and in turn forward. If its shorter its pulling the axle back toward the bumper closer to the point of connection. Im going to wack the stock one back on in the morning
And order an new onemaybe
CMF_DECIM8
No you are right... Turns out the axle spins when you lower the car to the drivers side. so I think ill lift the rear (its too low anyway) dont know how people drive like that anyway.
Hopefully it will rotate the axle forward 1 cm or so.
