The reverse light on my K12 isn't working.... I had thought it was a reverse light switch issue as that seems quite common.
So I got under the car and checked the switch with a multimeter, there was continuity between pin 1+2 and also 2+3 (2 being the shared live). So I popped the car in reverse and checked the wiring loom to the switch and I was picking up voltage between the plug connections.
To the back of the car and checked the actual terminal, with the multimeter and again with the car in reverse there was a clear 12V shown (when connecting the multimeter + to the brass prong that touches the bottom of the bulb and - on the silver metallic housing. Taking the car out of reverse and the voltage dropped to something like 0.005v, so I'm thinking the whole circuit is working correct?
So I thought it must be the bulb, I got some new ones but still the light did not work, I checked them for continuity and the bulbs were fine. I though perhaps the brass prong wasn't touching the bottom of the bulb so I bent it up a bit and still no light.
Now I may be missing something really obvious here.... or perhaps I just have the wrong bulbs.... but if I have voltage at the bulb the damn thing should light...... shouldn't it?
