can the rails be removed from the seat subframes, without rendering the slidy rail bit useless? so can i remove the seat and slidy bit but leave the subframe still?
i dont have my car with me and need a quick reply!
the frame can be bolted off tom. and you could cut the hinge/recline part off, or you can dismantle the sliding 2 halves (some ball bearings and plastic rods fall out tho )
well..... if you separate the lower 1/2 (ie slide the top 1/2 off completely) you will have 2 rails that will bolt to your floor (with the 4 bolt brackets, but you will lose the seatbelt mount )
you could need to either weld your bucketseat rails to it, or weld the bucketseat frame to it
Either way there is welding involved, I sold my nodded frames to kenny and carnt remember, i'm shure the clubmans came on the runners and I just welded the frame to them.
