radio security code
Have been looking at a few sites for retrieving radio codes one being radiocodeuk I removed the radio after watching a video on you tube that cuts out the need for removing the a pillar trims could not be easier flick up the dash above the radio with a thin bladed screwdriver to reveal a ten mill bolt be careful not to loose it behind the dashboard!!!!! open the cd storage compartment remove the twe square covers to reveal two screws then remove the two screws under the radio remove all screws and covers then pull out the radio and lift upwards to assist removal you can move the light switch stalk then the radio serial number and part number are on the side of the radio check out you tube and just want to know if anyone has used either e bay or radio uk to get codes?? e bay £1.99 radio uk £8.99 or anywhere else I can obtain the code radio displays wait 1 hr to reset code??
Lauro
