Hi the battery went flat on my Micra could someone help with a radio code please. I have a Radiopass card and serial no. is A3132883. Its not 14 characters and does not start with BP. Can someone please help me obtain the radio code?
If you have a 'Radio Pass card' surely it has a four digit pass code on it somewhere?Hi the battery went flat on my Micra could someone help with a radio code please. I have a Radiopass card and serial no. is A3132883. Its not 14 characters and does not start with BP. Can someone please help me obtain the radio code?
What does your 'Passcode' card look like? Is it similar to either of these?I have checked the Radio Pass card and it does not have the pass code. I have checked everywhere but I can't find it.
Define 'did not work'. What button are you pressing after inputing the code to confirm it? If that card shows the same serial number as your radio then the 'Safety-Nr' is your unlock code, which would suggest that you are not following the correct button sequence to put it in the radio......it looks like the second one. Unfortunately I tried the 'Safety-Nr.' number but it did not work.
