Radio code help pretty please
NISSAN micra 1.2 automatic
Blaupunkt CD Player
Nissan mm cdk
Bp334947296676
7643349318
I would be very grateful if any one can help out with the code for radio and tell me how to input it as currently have a wait1h sign
Image of stereo
Blaupunkt CD Player
Nissan mm cdk
Bp334947296676
7643349318
Code 5779
K12 Micra radio code entry, for example radio code is 1234, you have radio preset buttons on front panel of radio, using button number 1, ensuring that the display shows 0000, press button 1 till first digit reads 1 and then press button 2 till it reads 2 and then press button 3 till it reads 3 and same for button 4, depending on which model radio you have fitted to your K12 micra will depend on next stage but after you have entered the radio code into the unit the display will show your code, either press volume up or tune station up or press and hold the TA button, display will either show CODE OK
(I copied this from Yahoo)
Go to nissan they might help,I just replaced mine,or check ebay some people can decode them or give you original code think it's only 10 pounds
