Radio Code Frustration
Disconnected the battery so now being asked for the code. I can't find any piece of paper with it on so took the radio out to have a look.
Aghh a bit of paper stuck on it.. but it was ripped.. I can only make out the following
"28 184 BC401..... .54"
Stamped in the metal casing is
"LP 8 635 123 524-3"
I guess that won't be useful though!
Help needed!
The only code I have is on a piece of card with the original vehicle docs. Look for a 4 digit number somewhere in your docs. Remember not to enter the code as is. Each digit represents the amount of times you press the number keys on your radio in order. For example if the first digit is a 5 then press the 1 key 5 times and so on.
Sent from my KFTT using Tapatalk
