D
Deleted member 29304
At 12 midnight Monday-Tuesday morning 12th-13 Feb: My Nissan Micra K11 broke down with no real sign’s of what was wrong except the power of mtion was slowing and the temp gauge showed very hot I contacted my startrescue breakdown company & had to wait 90 minutes for the repair man to show up. In the mean time I bought some more antifreeze then topped up radiator myself once the radiator cap had cooled down & noticed that the rad was nearly empty. I was able then to drive home without the repair guys help.
On the 13th I removed the coolant expansion tank with some ease (as I had cut the black plastic tube away from the c/e/t sometime ago to make it easier the fill the coolant expansion tank) & flushed it out with fresh water and noticed that some bits of plastic and other foreign objects came out as well as the antifreeze. I then fitted it with a cover to hide the hole in the body of the holder and then refitted it the car & added more antifreeze, and then took it on 10 mile test drive just to make sure everything was OK!!!!!!!!!!!!!!!
