Where is the radiator hose located for emptying the coolant on my micra ?
I can see one at the very bottom of the radiator but seems to be in a
diffecult place to reach with a screwdriver to remove hose clip
You can do it off where the bottom hose joins the engine block and push it down under the car, but you might not get all of it out. Saves crawling around on the floor.
