Radiator fan no longer runs !
I've thought for a couple of weeks that the engine wasn't cooling as it used to (well I've had the car for six months) and confirmed it on the weekend - but I cannot really see why so I'm seeking your expertise...
I went out on my weekly trip of 30 miles - and at speed so that the temperature didn't actually rise too much - and on return left it idle and saw the gauge just rise, far above what it usually get to before the fan would have started, opened the bonnet and there was simply no fan action. So far I've checked:
- temperature gauge is obviously working
- the radiator is getting hot
- the fusible link is fine (0 ohms with meter)
but in the situation as described above there are no volts across the power lead to the fan, although, as yet, I've not checked that the fan will run (it was fine a few weeks ago) but it is certainly free to rotate.
It's worrying that it almost sounds as if it's the ECU not telling the fan to start. I haven't tried the diagnostics - but I'm not sure that they would say anything interesting and the engine check light in the instrument panel just goes off as usual and stays off.
Any suggestions on what to check next ?
thanks in advance
thanks in advance
