Bit of a noob question! I was wondering what size socket the spark plugs are for the nissan micra, what size spark plug tool will i require? Mine is a 94' K11 1.0L
Will this do?
Will this do?
Titch said:i'm to hungover to go out and look
Yes its 16mm socket plus extension (DO NOT overtighten the plugs you can strip the threads on these heads easy as they are only alloy, put them hand tight with your socket + extension then using a ratchet tighten a further half a turn to two thirds but NO MORE!) it should tell you this on your plug box but I thought I'd do my dad bit lol.:wasntme:silver_si said:the spark plug is 16mm. you can get a spark plug socket from a good motor factors to fit your socket set they arn't much, mabe a fiver?
I Hope this helps
Yorkie
revivng an old thread here. But I want to know if the 16mm socket will also work on the 2001 1.4 SE micra too.
I found this on Amazon so was thinking if it will do the trick
http://www.amazon.co.uk/Silverline-..._3?ie=UTF8&s=automotive&qid=1301924489&sr=8-3
