facelift micra's that had abs didn't have rear discs, just drums, it would be possible to do, but a major head ache. the brake pipes in the engine bay will be the worst job, maybe engine out!!!!
so to sum it up you'd need all the following off an abs equiped k11.
complete rear axle (might get away with just hubs and plate back if staying with drums), all abs sensors and wires, front hubs to bolt the sensors in, outer cv joints, servo and master cylinder?, abs control unit, all brakepipes from under bonnet, and fingers crossed if the under bonnet wiring is standard for abs.
i may have missed a few things out, but that is most of what you'd need.
