nothing specialy just a pretty rough guide
so start with the front
for the front drain, there is one on both left and right , those can be located by the interior kit panel (just a held on by 1 screw and a plastic nut)
plastic panel removed and showing the rear washer pipe
remove foam to get to the pipe
foam removed and the pipe has been pulled out ,
now ,this can differ alittle but , what i did on my yellow micra was extented the pipe with silicon pipe (fishtank pipe) routed the pipe along the inside of the sill, behind the carpet and the feed it into a hole that behind some tape rougly between the A pillar and the seat mount , then i removed the 2nd bung in the sill and feeding the pipe through, once through i drilled the bung and refitted with the pipe now sitting in the middle
that was my way there is other ways of drilling the sills and feeding it through or using the first bung and feeding the pipe through there with some wire taped onto the pipe
the first bung in the sill
its just rubber, the can become a bit hard but to come out, note becarefull if you got rust or rotten sills ,
now the rear drains
again there is two rear drains on both left and right
so one the 3 door as in the pic you will need to remove the inner rear trim , just clipped in and can be plied off fairly easy
then look inside the and you will see a fatish black tube (where the read line is) that is the rear drain
re route the pipe over the rear wheel arch to behind the rear light, for the left side with the fuel cap the need to route over the it
fed behind the light then fed out the vents
can also drill a hole and feed then out the inside or back of them aswell
just pull the carpet back
behind the light
you see the vent at the bottom just feed the pipe out there,
now just putting the pipes just out the vent does work but isnt ideal , may be better to drill in the side or back a hole or mod the vents so the vents can fully close , as they are in the pic the vents cannot close properly ,
also some 5 doors the rear drains are already routed down here and fed into the back of the vents via a hole
this is just a simpe and very rough guide , any input or better pics ect would be of great help/ improvment
thanks
thanks
