quick help please!
I'm trying to remove the head set surround on my '95 k11...
I've removed screws behind the ash tray and the 2 directly above the stereo/under the switch cluster.
But it's stuck at the top, around the switches and air vents. IT's an old shape dash.
Help please, oh wise and wonderful micra Gurus!
Yank it out carefully...
if you undo the 2 screws by the ash tray and two from underneath there is nothing holding the center console on other than the stereo if you have one fitted. just pull from the sides and work your way up they are normally just clipped in.
be careful not to yank out the cig lighter from behind.
