Question about Gaugepanel connector
Hello!
After searching the scappys for over a year, I finally found a gauge panel with an rpm gauge etc. Usually this should be plug and play. However, my friend has disconnected the blue wire that leads to the distributor from the main plug that connects to the panel. Does anybody know which plug (number) it needs to be connected back into? Seeing the rpm gauge doesn't work right now because of it. I have a 98 Micra (facelift).
Cheers!
Rick
Well the thing is.. the connector that goes into the clocks has no blue wire anymore, since my friend accidently pulled it out. I need to know which plugnumber it needs to be connected to:p
