It's in my blog. The engines a straight swap. The only thing you should do is swap the flywheels over as the 1.0 flywheel is 2kg lighter. This will give you a nice little boost seeing as you've got access to both.
The ecu could do with being swapped also, if you want the best performance. It underfueled slightly if you keep the 1.0l one on.
