g'day my fellow micra k10-ists !
this is claus from kiel in northern germany (if that matters).
im new to THIS micra forum, but member of german nissanboard since 2007.
the object is my k10 built 1992, 54hp, 1.2 ltr everything standadrd no frills,
an economic, reliable, practical, lightweight fully unspectacular little friend. i love it.
my question after changing brake pads and disc is:
WHAT IS THE CORRECT POSITION OF THE BRAKE PAD SLIDING STRIPS ?
they sit between a milled surface of the brake cylinder cast iron housing
and the arms of the brake pads, are made of stainless steel and avoid rust and friction.
on one end of these little strips is a FEATHERING ARM about 20mm long and 4mm wide.
my question is all about WHERE TO POSITION THIS FEATHERING FUNCTIONAL ARM
- is it mounted showing outside - into the air ?
- is it mounted showing inside, feathering against the anti dust bellows over the sliding bushes ?
- as the strips are mounted opposite: is one of these arms outside and the other inside ?
what is the function of this feathering arm anyhow ?
if it is to keep the pads free from the disc, avoid friction, overheating, rusting, premature brake failure ...
i appreciate it, as i have to grease and unblock the brake piston every 2 years.
this week i istalled new piston rings, rubber bellows and dust caps front and rear,
to avoid the annual brake service hazzle. thats why i am pedantic now.
repair manual doesnt show the details,, so all experience based advice welcome,
cheers
claus k10 from kiel
cheers
claus k10 from kiel
