Ok results..
Blue Monster (Aftermarket simple throttle body, no AAC valve or bypass valve, just a simple mechanical throttle body): Idling at 800rpm, with fast pumping of the brake pedal, revs climed to 1400rpm and you could keep them there.
White Super S (Full factory setup, apart from extractors): Idling at around 1000 (was still half cold), with fast pumping of the brake pedal, revs dropped to about 600rpm and you could keep them there.
My thoughts: The pumping is pushing air into the plenum / intake manifold. The monster has nothing so the extra air just makes the car rev more, like a mini turbo giving it more air.
The factory super s knows that this would happen, and perhaps its bypass valve or something tries to compensate by dropping the revs, but perhaps its overcompensating and hence they drop to around 600rpm..
Hmm!!
Blue Monster has the larger ABS booster, but now with no ABS. And seriously, the brake pedal is truly more powerful. Pumping through the ABS introduces a loss. But weird re:your ABS Yom, my old ABS and also shortcake like evade's never does that, always kicks in only pretty well when you need it.
