skymera Brutal Honesty Oct 9, 2012 #1 Got some ideas and going to play around with the top chain tensioner so it gets a little tighter. Still a bit of rattle when starting.. Will I run into any problems with chain if the tensioner is too tight? I'll be extending the tensioner by about 3mm
frank Club Member Oct 9, 2012 #2 you dont want it too tight eh skymera, if its tight enough to play a tune on it the alloy head bearings will run dry and seize
OP OP skymera Brutal Honesty Oct 9, 2012 #3 I best leave it then, not worth fiddling to save 1-2 secs worth of noise. Noticed my oil light stays on for 1-3seconds when starting, might look into that next
frank Club Member Oct 9, 2012 #4 skymera said: Noticed my oil light stays on for 1-3seconds when starting, might look into that next Click to expand... thats usually crank journals eh i think you should build a "special" personally
OP OP skymera Brutal Honesty Oct 9, 2012 #5 frank said: thats usually crank journals eh i think you should build a "special" personally Click to expand... haha shhhh. Just when I was thinking my engine was fine New year..... new gearbox, CG13 and a T2
SirChris Educated Bodger Oct 9, 2012 #6 skymera said: haha shhhh. Just when I was thinking my engine was fine New year..... new gearbox, CG13 and a T2 Click to expand... inspired
OP OP skymera Brutal Honesty Oct 9, 2012 #7 SirChris said: inspired Click to expand... Yeah, helped someone other day with his T2 CG13, gave me the taste for it. You may know him
SirChris Educated Bodger Oct 9, 2012 #8 skymera said: Yeah, helped someone other day with his T2 CG13, gave me the taste for it. You may know him Click to expand... Oh the bloke who don't have a clue what he is doing
