problem with the hazard warning lights
CMF_panos4
Hello
The car has a problem with the hazard warning lights and rear right lamps. Only the light bulb works in the rear right lamps. When I turn the signal light the upper bulb flashes instead.
When I press the button for the hazard warning melts the fuse for the "Hazard" and the immobilizer light goes out and the car will not start.
Does anyone have a schedule for lighting or any suggestions? It sounds like ground fail for me but what points should I check?
(Sorry for my bad English)
Thank you
