Hi,
I am having troubles with my passenger electric window in my 1999 3door Nissan Micra
So far I have replaced the window regulator and the window switch but still with no luck
The drivers side window works so it can't be the fuse, and when you press the switch either on the passenger side or on the drivers double switch you can hear the regulator click so it cannot be a switch problem
If anyone has any ideas I will be very gratefull
