Haylz
Been having some problems with the wheels today. There seems to be quite a bit of vibration there which wasn't there at all with the steel wheels on. The wheels are all balanced as I got them balanced the other day before they even went on the car.
At the moment I have cheap plastic spigot rings in them so they have the correct centre bore, I ordered some metal ones thru my local A1 motorstore from TSW which should be here by next week.
I'm hoping that the vibration is due to the cheap plastic spigot rings and the problem will be sorted after I put the correct TSW metal ones in.
What else could it be if it isn't that?? The wheels were off a civic CRX so the offset should be ok.
