Problem with heaters/blowers...
When i turn on my heater/blower things there is this ANNOYING rattling sound, obvisouly there is something in the fan...When i turn them up past level 2 its actually quite loud.
Its really important i get it fixed because its winter and i need my heaters to stop the my windscreen steaming up which its been doing...
Just wandering how i can get into the heaters so i can fix it...
The noise is so annoying!!!! seriously!!
cheers marc...(Y)
Look behind the glovebox from underneath
3 screws, a small corrugated pipe and an electrical connector and the fan will come out
You will probably find some leaves and other stuff in the fan.
Prise the cap off of the bottom and drip some odourless oil into the bearing (even some veg oil will do) and leave it upside down for an hour or two for the oil to penetrate
I did ours 2 years ago and it is still quiet.
Thanks Yer fixed now,
No leaves or other stuff though,
No just a dead mouse mangled up in the fan!
Nice! ...:wow::suspect:
Didnt smell tho at all must of been dead a long time...
Very easy to fix actually i thought it was gna be much harder.
