Problem with airbag light
CMF_waris07
I have a problem on my ANK11 Nissan March 4WD, with the airbag light on the cluster, this light keep Flashing and no stop, only when i turn off the car this light stop flashing..
What can i do?
Thanks!!!
CMF_LWC
Haynes manual says when you start the car it takes 7 secs for the airbag circuit computer test to be completed and the light to go out. If still on take it to a dealer as something is wrong with the circuit and not to try to fix it yourself.
However chapter 10 on how to remove the steering wheel with airbag says to remove the negative battery lead and wait at least 10mins before working on the airbag circuit......which you disconnect, remove the Torx screws and don't bump/hit/drop the airbag unit!!!
CMF_waris07
Thanks Guys for all your support, i fix the problem, well not me a dealer, the problem is when the battery level goes down for any reason the Airbag computer does not receive the signal that needs.
