Preface vs facelift k11 march gearbox
Hi guys & girls
I’m looking for some accurate clarification on the differences between a 92-97 Nissan march k11 automatic box to the 98-02 facelift automatic max.
What’s the differences? Is it possible fit a facelift auto box to preface
What’s involved if so
Thank you to anyone that sheds light
i doubt you would get the g/box ecu to work without changing the entire wiring looms
and the pre 2000 ones use a powder clutch
So basically to put either box into each other it requires full loom swap out more than likely ?
The auto gear box has its own ecu separate from the main ecu?
Hi frank just wondering would you know if a Nissan micra European/UK preface auto gear box would be the same as jdm preface auto gearbox?
yes gearbox control unit
the member on here with the cg auto trike might throw some light on it ?
