frank Club Member Mar 17, 2012 #2 The Bod said: or part Number for this item Click to expand... i keep a spare one for myself from an N reg bosch 950222 26RT7186 56222 6923 1117 0 261 200 957 23710 99B00 99B00-95800
OP OP T The Bod Mar 24, 2012 #3 I have been offered an ECU from a 1995 K11 can I fit this straight to my 19996 k11 and by pass the NATS system
OP OP T The Bod Mar 24, 2012 #5 Part No 23710 99B05 from this can anyone tell is if off a Manual or Automatic or will it matter
OP OP T The Bod Mar 24, 2012 #7 Tried a search but could not find if it's manual or automatic but will it matter ie will an automatic run a manual ecu
frank Club Member Mar 24, 2012 #8 there must be at least 10 threads that say that nats and pre-nats have different pinouts, and the cvt g/box has its own ecu iirc
frank Club Member Mar 25, 2012 #10 The Bod said: There are also many replies that say you can do a straight swop Click to expand... nah, you would have to fit the loom too, or else alter the pinouts
OP OP T The Bod Mar 25, 2012 #11 Easy way out although expensive I will ring ED tomorrow and see about ecu
