Powercoil springs!!!!
MICRASKYLINE
Not too sure how many members bought the 50mm springs from the group buy.
I have not fitted mine yet and just thought how are the springs for those who's had them fitted.
I have 35mm gmax and the 50mm powercoil ones- which one should I fit on my k11? also got the koni shocks to go on with the springs.
Do i need any other kit if i put the 50mm springs on or would i be ok with the 50mm springs and the koni shocks?
If you put on the 50mm get a Camber kit as your front tyres will wear out VERY quickly as I have discovered.... Ive had my tyres for about 2 months, they look like there about 2 years old.
Edit: Oh yeah, put the 50mm springs on! Just prepared to change tyres more than usual
You must have bad tyres or tracking jay, i have a 60mm drop with et15 deep dish alloys... i dont have them problems, perhaps your are unable to drive correctly or have one of the above problems...
Can you mix the springs - as in have 50mm at front and 35mm at back?
And how would it effect the ride?
Or even would it look as good as 50mm all round??
