I use the ebay one too!
If you are unsure you can do a few things. Pull out the cig lighter and wire to that (you'll need a slightly bigger fuse though) or buy a fuse with a wire comming out of it and choose a terminal to plug into. There may be a spare space with power too.
Jaycar sell those.
You cant connect directly to the battery as this will enable it to drain the battery.
