Power Steering Fluid Leaking Please help?
Hi guys,
I got pas micra so it is leaking from pas somewhere to the ground. It don't leak alot but if i turn with steering locked then it will be leak more.
Right now, its low level at the moment so i only got pagid brake dot 4 fluid and also bmw atf fluid. is it going to be ok if i can use bmw atf fluid or pagid brake dot 4?
How can i stop this leak?
cheers
jk
Did you leak because of nightmares?
Did this dream involve a tyrannosaurus using you for mouthwash.
If no then find you leak ASAP.
I think hydrolic fluid is usable?
no!
no!
ok, it is dark outside at the moment so i will have a look tomorrow morning. ok, i will have a look on hydraulic fluid now.
