hi everyone,
my car is a 2001 K11 1.0L auto (cvt) with 60,000 on the clock.
Its the face-lift Bosch coil pack and throttle body version
Did a test today and came up with an average MPG of just 35.4 (this is a mixture of town and motorway driving) the book says I should be getting a COMBINED figure of 46.5 even with a CVT auto box.
She's had a full service (correct Bosch spark plugs,oil + filter, air filter, fuel filter, coolant and gearbox oil change) now I'm thinking that the problem might be with the removable MAF sensor as she seerms down on power until the engine warms up to operating temp and at idle/tick over there is more noise than I would like and a slight judder that can be felt through the steering wheel.
On the move everything is ok....no hesitation or stalling problems....just bad MPG. I've cleaned the throttle body and sensor by spraying cab cleaner at it but that hasn't helped.
The engine management light did come on a while back but turned itself off after she was serviced!!!!! At the moment no EM light is showing. I've seen some MAF's on ebay, they're not the original Bosch but an aftermarket part......?
Any ideas would be very welcome.
Thank you
Thank you
